ZERACER
Yes, you must remove the console. On mine toward the dash is up and toward the rear is down.
You can remove the window switch bezel without removing the console.
Remove the rectangular trim piece, then remove the trim which covers the gear shifter. The cover for the gear shifter has to have the four snaps pried away from the shifter mechanism in a sideways direction rather than vertically like the other two.
The window switch bezel can the be pried up and out in a rearward motion.
Use plastic trim sticks.
The window icon on the switch goes toward the front of the car.
