Passenger window switch
Old Jul 19, 2021 | 10:25 PM
linneytron's Avatar
Default Passenger window switch
Passenger window switch falls below console, any suggestions?
Old Jul 20, 2021 | 01:03 PM
Default Re: Passenger window switch
You will have to replace it or glue it in with epoxy.
Old Jul 24, 2021 | 09:09 PM
linneytron's Avatar
Thanks, tried zip ties they worked for a bit really don't want to use epoxy in case i really need to replace it.
any idea how much a new switch is?
Old Jul 24, 2021 | 10:06 PM
Not sure a new one is available. Try here: crossfire window switch | eBay
Old Jul 24, 2021 | 10:28 PM
CaptainHero's Avatar
I don’t mean to hijack the thread but could someone tell me which way the button should be pressed to lower the windows? Toward the dash or toward the back of the car? On our car The two switches work in opposite directions and I want to determine which one is wrong and correct it. Also, is it difficult to remove and replace the switches? Do I need to remove the center consul to get the switches out without damaging them?
Old Jul 25, 2021 | 10:03 AM
Yes, you must remove the console. On mine toward the dash is up and toward the rear is down.
Old Jul 25, 2021 | 12:56 PM
You can remove the window switch bezel without removing the console.
Remove the rectangular trim piece, then remove the trim which covers the gear shifter. The cover for the gear shifter has to have the four snaps pried away from the shifter mechanism in a sideways direction rather than vertically like the other two.
The window switch bezel can the be pried up and out in a rearward motion.
Use plastic trim sticks.
The window icon on the switch goes toward the front of the car.
Old Jul 25, 2021 | 01:17 PM
very interesting, thanks
blackpepper
Oct 24, 2018 06:56 PM
Chadders
Sep 7, 2012 07:22 PM
shapeshifter309
Jun 10, 2010 11:58 PM
ghostface157
Aug 24, 2009 10:51 PM
Aknester
Jul 7, 2008 02:50 AM
