Old Aug 3, 2021 | 08:56 PM
onehundred80
Default Re: Ignition key gets stuck / throttle cable module
Originally Posted by Ironworker 6
Hey all, having the same issue with the key stuck in the ignition. Can start the car and drive it but can’t get the key out. Dealer recommends a new shifter module which is not available anywhere. Does anyone know where to get a shifter module or will removing the black park lock cable fix the problem or can the park lock cable be adjusted on the shifter end?
It’s a wonder the dealer did not recommend a new car.
Is your problem like that outlined in the attachment in my post #9?
The sticky ignition key fix.
