dedwards0323
While I agree with Valk's feedback above, you do have options. Even if you find a set of wheels you like that have a different (larger) hub bore, you can purchase a set of hub-centric rings that will press into a wheel's larger hub bore & convert the wheel to the 66.56 mm hub bore needed for the Crossfire. Tuners do this type of conversion all the time.
This is correct. those hub rings look like this...
