GraphiteGhost
The MB part number you have can, and does, cross-reference to many different clips. Way back (years) I got a bag of 25 off fleabay (Ebay) that fit and work perfectly for almost pennies each. YMMV, but if a name brand is what you wish then go with a MB supplied OEM part number. Also, this topic has (if not quite a few) a few posts about this exact clip. A google search is recommended but you can also use the forum search engine (some say the google search works better). Good luck!
So in their wisdom Mercedes gives the same number to different but similar parts?
I doubt that very much, can you imagine the confusion on the assembly line when the wrong part showed up?
I would say that the sellers of clips could get the number wrong easily.
