Old Sep 4, 2021 | 10:16 AM
mrmuppet's Avatar
mrmuppet
Default Re: SRT6 Water pump UK
Originally Posted by zip439
For as long as you have owned this car mrmuppet you should KNOW there are maintenance items which can not be ignored without expensive consequences. Sounds like you should get started before they hit your pocket book hard: siren? sticky key fix ?? all fluid changes??? RCM refurbished???? wing resealed????? all drains under cowl cleaned ????? Cabin filter replaced??????? Run any diagnostics lately??????? Alignment checked?????????? etc
Yeah other than full service every year I probably have neglected it.
siren? Not read about that
sticky key fix ? I did mention that today
all fluid changes? Just done whilst I have been awaiting other parts
RCM refurbished? Just had this out to check the operation of the relays, all working at the moment
wing resealed? Not read about that either
all drains under cowl cleaned ? All done, after the event
Cabin filter replaced? Done due to water egress
Run any diagnostics lately? Just ran this again and ran live data on the four speed sensors and now showing no errors - Car still won't rev above 5000 or change gear whilst under full throttle
Alignment checked? Done on MOT
It will soon be off the road again until the end of spring next year and not actually got it running this year yet.
