Re: Sticky Ignition Key Fix for all Crossfires 2004 thru 2006
Roniarnpc
Went through the whole tutorial and put the car back together and now the key turns but the car doesn't start. Initially it started and then turn itself off in a few seconds. Now it just doesn't start at all. Any ideas?
I see this is your first post. I don't have many posts here but you need to share with those who really know these cars what your problems were that led you to believe the Sticky Key Fix was the answer to your problem. The Sticky Key fix will fix a sticky or stuck key and nothing more. If you had starting issues that weren't related to a stuck or sticky key you fixed one known problem these cars have but you may not have fixed the primary problem that was causing your no-start issues. What was going on with the car that caused you to think the Sticky Key fix would remedy it? The more info you provide the more people here who are way more knowledgeable than I am may be able to diagnose your problem. When you did the sticky key fix were you sure to put that wired transponder/code reading ring back around the ignition that you had to pull and let dangle to take ignition out?
