Re: Sticky Ignition Key Fix for all Crossfires 2004 thru 2006
I did have the sticky key problem and the tutorial fixed that. But apparently, after I fixed that, the care started for ten seconds and then turned itself off.
After three tried it wouldn't start at all. We were dumbfounded because the key now turned. I called my brother and he said it was a safety or alarm issue
with Chryslers and he said to disconnect the battery for 30 minutes and the key will reset. We tried that and it started right up! Thanks for your help!
