CaptainHero
Can you lock and unlock the doors using the buttons on the center consul? Have you done the reprogramming procedure for the key fob after ensuring batteries were good? I am not an expert by any means, but if you have a key that starts the car you shouldn’t have to do anything with the ... If the console button works you could rule that out. It is odd that the second key would not start the car unless the transponder chip was removed or lost when changing the shell. I am wondering if the locking and unlocking functions could be related to the body controlModule
Thanks to you both for your responses. Two more things I just confirmed are:
1. The second key has no transponder chip. The dealership also confirmed they only used that fob as a service key.
2. The console lock button does not work. Will have to chase that down as well.
I REALLY APPRECIATE your guidance! Many thanks! John
