kowaltoboggan
Thanks for all of this exchange on this confusing, but important topic. I have two fobs. Neither of them opens the doors remotely or locks them. Both fit in the ignition and turn, but only one starts the car. I believe throughout all of this I have no way to lock the trunk as there is no trunk key. Am I screwed or does Needswings's skreem refurbishment and key rework service prove me (a costly) solution?
Can you lock & unlock the doors/hatch using the key itself in the driver's door handle?
I think turning the key to the right will unlock the driver's door. Turning it to the right again will unlock the passenger door, fuel fill door & hatch. Turning it to the left will lock all doors & hatch. Might be the other way around; haven't done this in awhile. Having a remote operating key fob isn't a big deal as long as your key(s) will lock & unlock the doors & hatch manually, so to speak. (Note: See Page 16 of attached file.) Others can chime in if I'm missing something.
It is the other way around (see Pg 12 in attached file).And you only need to turn it either way only once. Lefty Loosey (Unlock All Doors & Hatch); Righty Tighty (Lock All Doors & Hatch),
Had to go back & read this section again. More to the door lock system than I remembered.
