GraphiteGhost
Love this project! Been following since you first started posting on it. About this post, FL might have to have the A/C running 90% of the time but doesn't the A/C shut off during high S/C demand? Just a thought as I have not played with a S/C system before, am pretty sure A/C cuts off when a certain throttle response (& higher including WOT) is called for. Love your sticking with it!
You're exactly correct. A/C does disengage at WOT, hence the water tank which will hold the chilled water. 1 extra gallon will provide enough reserve for a 1/4 mile run. Also, they offer a kit with an electric solenoid that will turn off flow to the car's evaporator, eliminating water dripping at the track, and also at the same time boosting the KC efficiency. I did not opt for that one. Yet.
