Old Sep 27, 2021 | 07:00 PM
extremekustoms's Avatar
extremekustoms
Default Re: 100% E85 to 91 blends what can work
Still working on leaking intercoolers so i decided to install the 2 350cc injectors into the blower intake. The install went super easy and with the new to me rebuilt injectors, dc drivers and adj hob switch's i have less than $200 out of my pocket. Plan for 1 350cc injector to start spraying e60esh around 15psi and the 2nd around 18psi. see pics
Also ordered an 3.17 or 80.75 mm throttle body and plan to make an adapter from some 7/16" thick composite sheet i already have. Looks like there will be just enough meat in the blower intake opening to enlarge to 81mm but its going to be close. If not i will make the adapter from alum and simply weld it on
