Old Oct 1, 2021 | 07:35 PM
ku95's Avatar
ku95
Default Re: Will not use Jet oil in supercharger.
The AC Delco super charger oil is formulated for a roots-type super charger the kind of super charger utilized in the MB M111 inline 4 cylinder engine. The MB M112k v6 & M113k v8 engines utilize a twin screw super charger for which the AC Delco super charger oil is not specifically formulated.
Hello,
Thanks for information.
I think the difference of Roots or Tween screw type is compression method.
It is same that these have two rotating shaft combined with bearing and gear connected with one snout shaft which needs lubrication.
My point is that as Mobil jet oil melts plastic, it will affect rubber seal or break any tightness with longtime use.
Is here someone who expain why jet oil melts thin plastic cup?? Normal engine oil will not.
