Old Oct 6, 2021 | 10:57 AM
ku95's Avatar
ku95
Default Re: Will not use Jet oil in supercharger.
What is the part number and maker of the OEM seal?
I doubt that a suitable seal can be found.
The surface of most OEM seals might be worn like this, so I could not see.
OEM size is,
1. In-dia. : 25mm
2. Out-dia. : 37mm
3. Thickness : 5.5mm (~7mm might be Ok)
4. Type : one dust rip + double seal
I installed same size with one seal then it leaks.
