Redtoy2
I didn't think I could do it when I saw the board but decided to try and turned out to be fairly easy. Here are the steps I took.
1- Removed the old batteries.
2- Made a cleaning paste using baking soda and water (google it, there are many sites that describe the method) and did a first pass cleaning, that got most of the buildup off the board. Let the board dry overnight over 1 of the furnace hot air vent or you can use your oven set at 175 degrees.
3- Did a second pass cleaning using isopropyl alcohol.
4- Then sprayed the entire board with QD electronic cleaner and that was it. The solder mask is gone but the board comes out really clean.
I found the most difficult part of the job was removing the old solder and the old battery pins and soldering the new batteries in but it was worth the effort.
Have You taken any pictures of the Alarm board after the cleaning ? It would be interesting to evaluate the damage caused by the battery leakage . . .
Daniel
