Thread: A/C problems
Old Oct 27, 2021 | 10:18 AM
zip439's Avatar
zip439
Default Re: A/C problems
Originally Posted by vicvar
Thank you very much for the prompt response, I will start reading and I will publish the results of my tests, I hope to continue counting on your support .. thank you !!
I hope you have found the reading of the afore linked threads helpful. They give many solutions. Here is something that has helped me with electronic contacts that are simply old and not functioning as they should; Detoxit5 is the best cleaning solution to contacts I have found. You spray it into any opening you can find on a switch or potentiometer, spin the pot or open close the switch while it is wet and give it a minute to dry. Works really well. Here is a link at ebay; deoxit5
