Old Nov 3, 2021 | 02:03 PM
Stephie69's Avatar
Stephie69
Default Re: What fuel stabilizer for storage ?
This was surprising to read from drive.ca
For those of you looking for safeguards against the ravages of ethanol-blended gasoline, there are a number of precautions you can take. The first is that you can simply avoid it in the first place. According to Dan McTeague, a noted petroleum analyst, Shell and Esso 91 are both ethanol free. All other grades from the companies have some ethanol content, but the mid-grade blend is pure gas, which means it not only corrodes less than ethanol blends, but is less likely to deteriorate when stored. Don’t be misled into thinking higher octane gas contains less ethanol. In fact, it has more! The octane rating of pure ethanol is 100, but when it’s blended with gasoline, it performs as if it’s 112. In other words, higher-octane blends — Petro Canada’s 94 and Esso’s 93 — use more ethanol, not less.
