Old Nov 12, 2021 | 01:34 PM
  #75 (permalink)
Coyote's Avatar
Coyote
Default Re: AT Tranny stuck in gear
High Gang, glad to see that this forum is still up and running. Been reading through this thread, as after 17 years of ownership of my SRT6, I have now had my car go into limp mode, showing the expected P0715 on the OBDII scan. Called the dealership where I bought the car, and where I have had various repairs and service performed over the years, and the was told they no longer work on Crossfires. So, though I've never cracked a transmission before, it looks like I'll be doing this repair myself. I'm not what you would call a skilled mechanic, but I'm pretty good with bolt-ons, replacing gaskets and sensors, replace circuit board, etc., but this one seems a little out of my skill set. However, if it merely requires removal of an access panel to get to the plate the speed sensor sits on, I think I can handle it. I assume the service manual, of which I have a copy, will provide the procedure, and I'm pretty good at following directions.
The only real problem I face right now, is I didn't see a part number listed in the thread. Does anyone have that part number? And know from whom it might be ordered?
Thanks in advance. This forum has been very helpful in the past. BTW, if anyone knows of a good, competent mechanic in the area of Cobb County, Ga. I'd be appreciative of a pointer.
