nemiro
There is a trim seal at the bottom outside, but the window itself, while it does also use a few nuts to retain it, is sealed in with glue. We recently cut a pair out of a parts car we had here. We used a standard box cutter with a sharp blade, patience, and a dose of bravery
So I ordered a used one with the seals around it in good condition. I'd imagine the glass service should be able to put that one back in and problem should be good to go right?
