Water leak through the quarter glass
Old Nov 12, 2021 | 09:19 AM
nickwe21's Avatar
Default Water leak through the quarter glass
Hi everyone!
So basically I had the right side of my crossfire painted recently due to clear coat damage from Florida sun.
Body shop told me they had to hire a glass company to cut out the quarter glass in order to paint. Apparently that glass company glued it back in but I noticed water is leaking into the car from the window on that side.
So essentially they had to look at it again of course and said the seal around that glass is brittle from the sun and that's why water is getting in. It got damaged when they removed the glass cause the rubber is brittle.
What can be done here? Is there any part I can order to reseal this? Would I be able to order that window on ebay that comes with the seal?
Thanks for letting me know suggestions.
Nick
Old Nov 13, 2021 | 04:47 PM
nemiro's Avatar
Default Re: Water leak through the quarter glass
I believe that the quarter glass is just glued in with windshield adhesive. No actual gasket.
Old Nov 13, 2021 | 04:49 PM
nickwe21's Avatar
Glass guy said the seal around it was brittle and that's where air/water is getting in. I looked on eBay and saw the window does come with seal around it. Might just have to order one there and then have them glue that one in and hope it seals properly.
Old Nov 15, 2021 | 08:57 AM
nemiro's Avatar
There is a trim seal at the bottom outside, but the window itself, while it does also use a few nuts to retain it, is sealed in with glue. We recently cut a pair out of a parts car we had here. We used a standard box cutter with a sharp blade, patience, and a dose of bravery
Old Nov 16, 2021 | 01:47 PM
nickwe21's Avatar
So I ordered a used one with the seals around it in good condition. I'd imagine the glass service should be able to put that one back in and problem should be good to go right?
dcskmail
Jun 20, 2021 05:13 PM
silamanajik
Sep 11, 2016 11:37 PM
rdooley79
Oct 1, 2009 04:35 PM
blackcrossfire07
Mar 15, 2009 06:28 PM
70GT6
Detail Shop
Jun 16, 2008 05:11 PM
