TomBishop
I'm Alessandro from Italy Rome and in the past I had a lot of issues you can find in this post, now they seem solved, really a lot things done and it should be hard understand what it worked.
For sure I always follow what I found here.
Thanks for all the help!
This time the main issue is the radiator fan who start and never stop. Probably the cause as I can see upper, it could be a dead battery.
I changed the fan relay and the mechanic tried different things but it seems impossible to solve.
Any other help will be really appreciated, thank you in advance!
Hi TomBishop, is it the same issue of turn the key and lights come on but the starter does not click or the starter clicks and starts but then shuts off?
