Old Dec 27, 2021 | 01:29 PM
UrbanE's Avatar
UrbanE
Default Re: All components of SRT6 supercharger.
Originally Posted by Shahasa
How do you feel about the hot & cold method? Tapping out the old bearing then cooling new bearing & heating the pulley. What size torx wrench would I need & what size wrench to remove the pulley bolt? Can I use hose clamps to hold the clutch or should I get a belt wrench?
The hot cold method does work, I’ve done it before and you have nothing to lose.
i built a press (instructions from you tube) for the second bearing I had to R&R
