Drmorton
Thank you for your reply...Yes...please take a look later at the slk230...I have an slk230 that has been setting for a year...I have rebuilt everything on this car, replaced the ECU, SKREEm and the ignition system, but no crank...I have actually gone thru 3 ECU/s trying to reconcile the crank issue...I can bypass everything and make the fuel pump and the starter work but something has to control the firing and fuel mixture (ECU)....Thanks again...LP
You need the Skreem ECU and Keys from one SLK to get the immobilizer to get to work.
In the Key is the transponder who is married with the Skreem, and the Skreem is married with the ECU
And if this also don't work, change the ring antenna who sits over the ignition switch If the ring antenna is defective you have also the typical skreem problems.
But when you have a issue with the immobilizer the car would run for a few seconds (2 or 3 tines) after disconnecting the battery for a few minutes.
If this doesn't happened you have a other problem, maybe RCM Module
