Old Jan 9, 2022 | 06:46 AM
ku95's Avatar
ku95
Default Re: All components of SRT6 supercharger.
Originally Posted by Fla_Xfire_SRT
~ I had PSE Superchargers rebuild mine, and supply me with the last 2 known OEM pulleys and bearings from a Fiat warehouse in the UK. It's on a shelf as a spare in my shop. The price was not cheap by any means. Over 5G for all.
~ I was told that to remove one of the bearings, not sure which, the unit needed to be heated to around 800 F in an oven to melt the epoxy from a grooved bearing and that any other method to remove that bearing usually results in damaging the casing of the S.C.
~ Your photos reveal that the teflon coating is gone from your twin screws not to mention the scratches. I didn't spot the bearing with the epoxy groove but I am curious how you removed it.
Hello,
There are epoxy grooves where bearings are located.
I think these epoxy is for thermal expansion of bearing or casting of S.C.
So It must not be melted because it should work.
Bearings could be pulled out with press machine and some handy tools without heating but it was not easy work.
Please refer to below pictures.
One important thing is that middle 2-bearings should be installed front face each other.
