Old Jan 17, 2022 | 05:56 PM
  #43 (permalink)
pizzaguy
Default Re: Convertible Top Sensors
Originally Posted by MCPO
Pizzaguy,
Can you tell me how to get at the Latch Retainer Switch to see if it is working??
MCPO
Best way is to not do that. Instead, pull the trim from the trunk and access the PTCM and measure the voltage on the pin of the wire going to the switch - way easier than taking the frame apart.
Pin 16 of C1 should go LOW, that is, zero volts when you "pop the top". WIth top up and secured, you should see 5 volts.
