Old Jan 23, 2022 | 08:10 PM
direwolf's Avatar
direwolf
Default Re: I need HELP with my R170 not starting
Originally Posted by MAGNATUDE
On a related no-start issue: My Crossfire would not start.
I found my problem to be a loose battery ground cable contact to the chassis. The car started right up when I re-attached the cable after cleaning the contact points at the chassis and the battery ground cable.
This should be in every 'electrical issue' thread / a crossfire mantra. Clean the battery ground at the chassis.
Along with Pull / Clean and Reseat each and every fuse.
