Old Jan 24, 2022 | 04:50 PM
crowz's Avatar
crowz
Default Re: I need HELP with my R170 not starting
Measure resistance across the that last link that shows to be the alternator. If it has continuity from the bus bar side "where it bolts on" and the side coming out of the wire "the other side of the fuse thing" its not blown. Other method if the battery is connected then check for power on the fuse side that towards the wire aka away from the bolt side. If there is power there its not blown.
