Old Jan 27, 2022 | 01:31 PM
pizzaguy
Default Re: top windows don't go down after unlatching top
Originally Posted by ZERACER
You can open the trunk through the license plate light. The procedure is on Utube. I would then check the fluid level first.
This may be good advice. You CAN open the trunk thru the plate lights, there are actually two methods.
Driver's side light - insert about a 10 inch coat hanger with a hook on one end and snag teh emergency release cable, the trunk will open.
Passenger side light - use a screwdriver to move the cam - the trunk will open.
I like the first method, most others like the second method.
