Old Jan 30, 2022 | 05:50 AM
  #47 (permalink)
THETESTER's Avatar
THETESTER
Default Re: I found this part to be the cause of the erratic climate control fan speed
Originally Posted by bc75
It was A1708301085. I had to trim some of my dash bezel by the heat control on the unit. It didn't take just a couple of minutes with some sand paper.
I noticed that the item you quoted is a different "shape" to our Xfire units i.e the internal circuit boards have been positioned to make the unit deeper. This should not make any difference as the functions should be exactly the same, however, can you confirm that it was a direct plug in replacement to the existing Xfire wiring harness?
