Old Jan 30, 2022 | 06:09 AM
  #48 (permalink)
bc75's Avatar
bc75
Default Re: I found this part to be the cause of the erratic climate control fan speed
Originally Posted by THETESTER
I noticed that the item you quoted is a different "shape" to our Xfire units i.e the internal circuit boards have been positioned to make the unit deeper. This should not make any difference as the functions should be exactly the same, however, can you confirm that it was a direct plug in replacement to the existing Xfire wiring harness?
Its the same.Before i bought it a was on the slk forums seeing if they had the same problem as we do. I couldn't find one complaint about the fan speed. So i thought i would give it a try.
