onehundred80
To my knowledge there are three Mercedes covers that fit on the Crossfire, trouble is two of them are too thick and rub against the hood liner.
The thickest one needs the hood to be forced down a little, the liner rubs against the cover and marks it.
Itook two covers to our local dump after I found the one that fits.
The original Crossfire intake tubes fit nicely inside the Mercedes cover.
I will add the Mercedes cover part numbers I used and the set up I ended up with.
(CLICK)
I looked at your setup.
So, I guess that means the air box I bought will only work if I upgrade the stock throttle body and MAF to the larger 74 mm ones?
If that's the case, does this mod provide a bit more HP ?
