Old Feb 10, 2022 | 10:13 AM
onehundred80
Default Re: Air/Intake question...
Originally Posted by Buck62
I looked at your setup.
So, I guess that means the air box I bought will only work if I upgrade the stock throttle body and MAF to the larger 74 mm ones?
If that's the case, does this mod provide a bit more HP ?
The diameters where they fit the throttle body are all the same. Same donut seal as well. My post on this subject shows the two throttle bodies side by side and you can see the outside diameters are the same but the inside diameters are different.
No noticeable HP will be the result, my post is for fitting a Mercedes engine cover which uses larger filters, a 75mm throttle body, a 75mm throttle and a EuroCharged tune. This did give a little more HP, maybe ten max. It came to about an estimated 195 HP in all, not enough for me so l got an SRT the very next year (2011) which I still have. One ride in Rudy’s SRT at the 2010 Woodward GTG told me I had to have one.
