Old Feb 13, 2022 | 03:34 PM
Charles Xavier's Avatar
Charles Xavier
Default Re: ABS ESP/BAS light won't turn off
[/QUOTE] Ive never changed my Vehicle Speed Sensor on the transmission but another posted, "The speed sensor is mounted on the electrical plate located just above the sump pan. Remove the pan, remove the plate and replace the sensor if required." Maybe others can confirm this. [/QUOTE]
Well sounds like its gonna be a pain to try to get under there but ill start there and if that doesn't work ill try some other ideas. Thank you
