pizzaguy
#5 Fuse in which fuse box location? And they moved fuses around over the years - does the car have heated leather seats (Limited) or manual cloth seats (Base)?
We've found several discrepancies in fuse locations versus the only service manuals we have on this site: The 2004 Coupe manual and the 2005 SRT Roadster manual.
If it's fuse 5 in the underhood box, it should be a 25 amp fuse and it feeds the power top controller and pump. If this blows right away, it has to be a bad PTCM. IF it only blows when you attempt to move the top, I'd think the pump motor is probably the culprit.
The fuse locations changed every time they built a car. The only way to know for sure is to confirm with the card inside the underhood fuses. Usually they are wet and damaged or missing.
I believe he is talking about the spoiler switch on the dash?
