Old Feb 18, 2022 | 05:37 AM
WD40's Avatar
WD40
Default Re: Crankshaft Position Sensor Modification
Originally Posted by Deepsea21
My Ford F150's fuel pump relay was made of aluminum and bolted directly to the steel frame. I read about fuel pump issues with the F150 and 80% of the time it isn't the fuel pump but the Fuel Pump relay completely corrodes since it was attached to steel (wonder who the genius at Ford was who came up with that OEM attachment method and placement). I went under my F150 and luckily caught it in time... The back side of the relay where it was touching the steel frame was corroded to the point I pushed my finger right through it into the electronic insides. The replacement I put in came with stand-off rubber bushings so the aluminum Relay does not come in contact with the steel frame.
This guy presents an alternative to completely separating the dissimilar metals: (best watched at 1.5 speed)
