Old Feb 27, 2022 | 04:37 PM
zip439's Avatar
zip439
Default Re: Recommended Lowering Springs?
Originally Posted by kemiel
I am thinking of lowering kit, but i dont know if my existing tires will be ok. 285 35 19 rear and 225x40x18 fronts. Can you tell me of a good priced set, with no issues or minimal, thanks kac
Your tire sizes are fine. If you want a softer ride the Eibachs will give you that. I took a Eibach Pro Kit off my SRT6 as I didn't think it could handle emergency maneuvering above 75 mph; Just way too much sway for me. I went back to the OEM springs. I have H&R springs, shocks and sway bars on my Limited and it rides stiff, (lowered about 1.4 inches) but I am much more comfortable driving that car at speed in curves and high speed maneuvering. There is a huge difference. So why are you lowering the car?? You have to have a definitive answer to that and then live with the consequences and if you lower it you must find a way to adjust the camber both front and rear or you will wear the inside of your tires out very quickly. The stock OEM suspension has no camber adjustment.
