Old Feb 27, 2022 | 09:17 PM
crowz's Avatar
crowz
Default Re: My double din install adventure
I have the factory speakers, they are good enough fo me and my lead ears.
I imagine they are. But that was the entire point of my post.
The problem I am having is because george replaced the factory subwoofers with aftermarket pyle subwoofers. The factory amp is not large enough to drive the aftermarket pyle speakers correctly.
If the car still had the factory subwoofers I would not be having this problem.
The rolled eyes you did seemed to reflect that you thought I was saying the factory subwoofer woofers were not big enough or something or that the factory amp wasnt big enough with a factory speaker setup.
I personally would of been happy with the factory subwoofers but since they were replaced before I got the car that isnt something I can do anything about.
So the logical solution is the replace the factory amp considering the amps easier to change than the speakers are honestly. This will also allow me to use higher quality door speakers when they fail from old age eventually.
