Fixed non-operating top & spoiler with $2 switch, thanks to this forum
permalink
03-07-2022, 02:52 PM
bucker
Re: Fixed non-operating top & spoiler with $2 switch, thanks to this forum
Switch is located under trunk lid (black cover removed). Screwdriver in image below pointing to location
You can use a jumper wire as shown below to make the BCM think the spoiler closed/down switch is closed (spoiler is in lowered position). With this jumper in place turn on your car and use the D ring on the top to open it. If this switch is your issue the windows will automatically lower when you twist the d-ring and pop up the top. The BCM logic will not let the top lower if it is not seeing a switch closed signal from spoiler down limit switch and the trunk closed limit switch.
Like
CROSSFIRERUSH
(03-21-2022)
bucker
View Public Profile
Send a private message to bucker
Find all posts by bucker
