Old Apr 6, 2022 | 01:44 PM
philosophico's Avatar
philosophico
Default Re: Transmission fluid type?????
Originally Posted by hannahabuata
I saw the kit you linked when I was doing my own searching as well. I am doing a full flush including the torque converter and from what I have read throughout this forum is that I will need 8.5 quarts for a TC flush. What is not needed in the kit? Could I just order the fluid and the filter and be fine? Thanks.
The one you posted had bolts that aren't not needed and that green piece is not needed. I didnt know you were doing a full flush so in that case yeah you will need 2 jugs of trans fluid. You can just older the filter and fluid but I recommend you get a new trans connector and replace that while your down there. https://www.fcpeuro.com/products/mer...tor-2035400053
They are known to leak and can destroy your TCU, so you might as well replace it while your down there.
