Old Apr 11, 2022 | 09:51 AM
mikec212's Avatar
mikec212
Default Another non starter
Cranks well - no start. Will start perfectly with fuel into induction
No sound at pump and putting 12v from power pack onto the pump- nothing, seems dead -
These worked fine - Opened the RCM, turn the key to the ON position. For 2 seconds the 3 middle relays should close. After 2 seconds the fuel relay will open, leaving the other 2 closed. Also getting battery voltage between pins 3 & 5 on relay
However no voltage at the pump terminals. Fuses all seem to be ok.
Car had been sitting for 6 months, just put new battery in, had the passenger footwell water issue that corroded pins in the amp unit etc.
Question is there any wiring loom connections in that area from there to the pump that could be affecting the 'no power' to the pump or suggestions?
Thanks
