Old Apr 11, 2022 | 02:47 PM
GraphiteGhost
Default Re: Another non starter
Originally Posted by mikec212
Many thanks for the reply, will have a look at these next. Fuses all appear good, both in the fusebox and in the RMC. Motors only done 40K, inside the RCM is spotless, have re done the solder etc.
No pressure at the schrader valve - no sign of rodents Yes the pump should run for 2/3 seconds but didn't, the relay closed a few secs as it should and gave out 12.8 V when I tested. So I did the same test on the + / - supply at the pump, showed nothing. Sort of accepted the pump is possibly shot, more surprised with the lack of V at the pump terminal even when primed for those 2/3 seconds?
Will run a separate temp wire from relay to pump end of loom and re-investigate etc. Cheers Mike
mikec212, I believe you will not find +12 volts on the pump UNLESS the RCM relay is CLOSED. If it is open, you'll not see anything.
