Old Apr 11, 2022 | 02:52 PM
mikec212's Avatar
mikec212
Default Re: Another non starter
mikec212, I believe you will not find +12 volts on the pump UNLESS the RCM relay is CLOSED. If it is open, you'll not see anything.
Yes I'm aware of that - I did say I got battery voltage when the fuel relay closed as it should for the 2/3 seconds - but no voltage for the 2/3 seconds at the pump end.
