Old Apr 12, 2022 | 09:24 AM
Jack G's Avatar
Jack G
Default Re: Cracks in my DRIVE belt ... now what?
FYI. Attachment shows the location of the tension retainer pin inserted in the pulley tension assembly. This is usually supplied installed when installing a new tensioner assembly. The pin is removed once the new belt has been placed in position and the pulley tension is temporarily relieved using a breaker bar. While holding the pulley tension with the breaker bar the pin can be removed. Slowly releasing the breaker bar force causes the belt to be tightened. Remove the breaker bar and start the engine to make certain the belt is properly tracking.
