Old Apr 21, 2022 | 12:14 PM
onehundred80
Default Re: Amp Plug B - BL/DG wire missing?
Originally Posted by mikec212
Got a replacement amp due to water damage, the 2 live Y/RD wires had broken away. Came with pigtails, as I was beginning to start splicing I noticed that the 'new' plug didn't have a blue/green wire at pin 2 as mines did (nor there was a pin inside the plug). Have noticed a few pics online and see that appears normal. All other wires in both plugs are as should be, notice on the wiring diagram there nothing at pin 2?
Is the differences in model/year looms that this is the case?
Amp plug B original on left
If need be you can usually remove the wire in from the old socket and slip it into the new socket.
To do this you slip a thin pin or drill down the front face and push the barb against the wire and pull the wire out from the back of the socket.
There may be one or two barbs, usually you need to open the barbs up again as the material is often soft.
