Old Apr 22, 2022 | 04:18 PM
  #53 (permalink)
pizzaguy
Default Re: Convertible Top Sensors
If the fuse blows as soon as you put it in, pull the connector from the pump, if it still blows as soon as you put a new one in, pull the connector to the PTCM. The device you last unplug is blowing the fuse.
If the fuse only blows when the pump starts (because you hit the button), the pump motor itself is almost certainly the cause.
