Re: Headlight Tab Repair.
I do not have dimensions handy, but I did do a repair almost identical to what you are describing. I trimmed the remains of the original tab off, and then bent an "L" bracket, which I pop riveted to the housing, and then drilled/tapped the 5x0.8mm hole for the mountin bolt. Works like a charm!
