Headlight Tab Repair.
Old Apr 30, 2022 | 12:44 PM
ATX SRT-6's Avatar
Default Headlight Tab Repair.
I going to repair this broken tab on this headlight by backfilling with epoxy then screw a 1/8" x thick aluminum plate extension on top. Then attach a speed clip .
Could someone measure theirs and provide the dimensions shown in the photos please? And what size is the bolt? 10mm?
Old May 2, 2022 | 12:30 PM
nemiro's Avatar
Default Re: Headlight Tab Repair.
I do not have dimensions handy, but I did do a repair almost identical to what you are describing. I trimmed the remains of the original tab off, and then bent an "L" bracket, which I pop riveted to the housing, and then drilled/tapped the 5x0.8mm hole for the mountin bolt. Works like a charm!
Old May 2, 2022 | 12:54 PM
ATX SRT-6's Avatar
I think the mounting hole is 1 5/16" from the face and level with the top? M5 x 0.80 is the bolt size?
I thought about doing what you did but was afraid I would pole through to the reflector.
Old May 2, 2022 | 01:13 PM
nemiro's Avatar
It will not hit the reflector, and the pop rivet will not back out, like screws will. From memory the thread is indeed M5x0.8mm
Old May 2, 2022 | 02:15 PM
Ronman's Avatar
The top headlight bolt is M5-0.8 x 12mm with a locked in washer
Old May 2, 2022 | 05:00 PM
ATX SRT-6's Avatar
Thanks for the fastener info. I'm going to use a u nut like these.
Sandy
Jan 22, 2023 11:26 PM
Toolman
Feb 27, 2015 08:53 PM
iCarfly
Dec 30, 2012 10:36 PM
Stogey
Jun 20, 2011 10:51 AM
mikep330
Jun 25, 2009 07:23 AM
