Old May 9, 2022 | 12:06 PM
Rbegora's Avatar
Rbegora
Default Top won't go up or down
I have an issue with my top:
Open top with d handle and windows go down and the red light on the button lights up.
Nothing happens. I have unlatched the divider and the trunk and each case the fault beeps which indicates that both switches are working. Reading Pizza Guys posts, I have tried to manually raise and lower the top. When I raise the top to the complete position, just prior to closing it down with the d handle, the system starts beeping that there is a problem. Even after I close the top with the d handle the beeping continues. I had to disconnect the battery and that seemed to cure the fault problem. But every time I raise the top, the same thing happens. I originally thought the problem was the top open switch but that does not account for the fact the top won't go up either. Since the top does not go up, am I correct in assuming the top open switch is not the problem?
Thanks for any help.
