Old May 10, 2022 | 07:06 PM
pizzaguy
Default Re: Spring start up problems
Originally Posted by plugs1
Would a weak battery also cause the speedometer not to work?
No. That's a sign the traction control relay's 12 volt feed to the brake controller has failed.
Blown fuse on the RCM
Bad solder connection on the RCM
Bad Traction Control relay on the RCM
.... or similar fault. This is getting to be common with our aging cars.
