Thread: rough shifting
Old May 12, 2022 | 08:12 AM
UrbanE's Avatar
UrbanE
Default Re: rough shifting
Phil
Please tell us again
Exactly, how did the gears get damaged? What did YOU do to cause the failure.
I’m sure all of us would like to know how much $$$ this error set you back
What did you learn by your experience that caused your manual transmission to fail. We all know what the Owners manual stated, you’ve mentioned it across 4 separate threads but, WHAT DID YOU LEARN!!!!!!
what wisdom other than we should NOT repeat what you did, should we take away from your expensive transmission fail.
The forum has been around for a long time and this is the first self inflicted transmission post that I’ve read.
Please share the details associated with the cost of repairs so that we can all be aware of the cost associated with not knowing what you’re doing. You post a lot so sharing should not be of concern to you.
